Keep alive timer is expiring between sup and WISM
hassan_si
Dear all,
I am seeing the below log continously.
Jul 19 08:30:26.734 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 8/1
Jul 19 08:30:27.754 UAE: WiSM-Evt:dman_reg_arp_added: cntrl 4/1 got an ip 192.168.10.70 0017.e0a6.6142/0017.e0a6.6142
Jul 19 08:30:34.270 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 3/1
Jul 19 08:30:34.270 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 3/2
Jul 19 08:30:34.270 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 4/2
Jul 19 08:30:34.274 UAE: WiSM-Evt:dman_reg_arp_added: cntrl 8/1 got an ip 192.168.10.90 001d.45ef.a362/001d.45ef.a362
Jul 19 08:30:40.362 UAE: WiSM-Evt:dman_reg_arp_added: cntrl 3/2 got an ip 192.168.10.60 0017.e00c.8b82/0017.e00c.8b82
Jul 19 08:30:41.526 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 8/2
Jul 19 08:30:42.762 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 4/1
Jul 19 08:30:46.526 UAE: WiSM-Evt:dman_reg_arp_added: cntrl 8/2 got an ip 192.168.10.100 001d.45f0.d482/001d.45f0.d482
Jul 19 08:30:46.734 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 8/1
Jul 19 08:30:54.270 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 3/1
Jul 19 08:30:54.270 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 3/2
Jul 19 08:30:54.270 UAE: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 4/2
Jul 19 08:30:55.542 UAE: WiSM-Evt:dman_reg_arp_added: cntrl 8/1 got an ip 192.168.10.90 001d.45ef.a362/001d.45ef.a362
Jul 19 08:30:59.266 UAE: WiSM-Evt:dman_reg_arp_added: cntrl 3/1 got an ip 192.168.10.50 0017.e00c.59a2/0017.e00c.59a2
Jul 19 08:31:01.462 UAE: WiSM-Evt:dman_reg_arp_added: cntrl 3/2 got an ip 192.168.10.60 0017.e00c.8b82/0017.e00c.8b82
I would like to know why its happening and how to fix it.
Scott Fella
What code are you running. If you do a search, you probably can find your answer as this was an issue, but it depends on your code. Search the forum and you will find your answer.
-Scott
Saravanan Lakshmanan
These debug commands are issued from the router (Sup720) CLI.
     Router#debug wism wcp {data/errors/headers}
     Router#debug wism events
These debug commands can be issued directly from the WiSM CLI.
     WiSM-A#debug wcp {packet/events}
Router#show wism status
