LAN Controller for multisite locations
jmathew01
Visitor
hello
can anyone help me with a particular scenario i am up against. we have multiple office in different cities, all connected via MPLS circuit...would i need a LAN controller each site or just on central with HA?
Leo Laohoo
There are several ways of doing this:
1. Central WLC if the WAN links are big (>20 Mbps);
2. Flexconnect; or
3. Mobility Express.
NOTE: For #1 will depend on how many APs per site.
Scott Fella
Central with HA and AP’s in FlexConnect.
-Scott
Take a look at this guide. There are many other guides and blogs in regards to FlexConnect
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/Enterprise-Mobility-8-1-Design-Guide/Enterprise_Mobility_8-1_Deployment_Guide/ch7_HREA.html
-Scott
Jonas Kalldert
Level 5
Level 5
In that scenario I would run a WLC in HA and having the APs in Flexconnect.
Another option would be look at Cisco Meraki that uses a cloud controller that way you dont need have the APs depending on a central WLC.
regards,
Jonas
**Don't forget to rate helpful posts**
