LAN controller
Mubarak ali Ali
Community Member
Dear All ,
I have Cisco Wireless LAN controller AIR-CT5508-K9 ,I had created a Web Authentication page for Guest VLAN users ,its giving the error "ERR_CERT_DATE_INVALID" when the users trying to access web-auth Page .
Kindly support me for the issue.
Thanks.,
Scott Fella
If you haven't installed a 3rd party certificate, your guest users will see a certificate error because the wlc uses a self signed certificate. If your on v7.2, I believe that's the code this feature was introduced a, you can disable https for web auth.  This way you don't get a cert error.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/115951-web-auth-wlc-guide-00.html#httpnots
-Scott
-Scott
Abhishek Abhishek
  • Try to set your date one day ahead of today.
  • Close than open your browser again. Hope it would work
mohanak
the real workaround is disabling HTTPs, and SSH (everything related to certificates) then save configuration and then a reload is a MUST.
MAKE SURE YOUR SYSTEM DATETIME IS CORRECT.  Check the little clock in the bottom right of the Windows taskbar.
