Dear Experts,
I need to configured QoS in LAN and on WAN.
My Basic Toplogy is as attached. Please help to configure the QOS.
If I will use Auto QOS than
1. Which command I need to apply on the switch Ports connected to Avaya IP Phone and PC is connected?
2. Which Command I need to apply on the switch ports connected to Avaya CM server or other Voice Servers?
3. Which command I need to apply on the switch port where only PC is connected?
4. Which command I need to apply on the port where other switch is connected i.e. trunk ports?
5. Which command I need to apply on Cisco 3750 Distribution switch? Should I need to apply auto QOS command on all ports?
6. Which Auto Cmd I need to apply on Cisco 4500 COre switch? I required to apply on all ports?
7. What Command I need to apply on Router for Autp QOS?
Please help.
