Wireless QoS help?
jamesshen
Frequent Visitor
Frequent Visitor
I don't understand how QoS Profiles (Platinum,Gold,etc) and Queues work with WLCs&APs.
Q1. How does the WLC queue packets ingress and egress? FIFO? Any documentation?
Q2. How does the AP assign a packet to the Queue? based on 802.1p? Or any packet on the WLAN with Platinum profile will be put into Voice queue irrespective of the 802.1p?
Q3. Leading from Q2 - Does the WLC or AP remark QoS of traffic from the Switch or User according to the QoS Profile?
eg. packet with 802.1p=0 comes into WLC from the switch on a VLAN with Platinum Profile, does it get changed to 802.1p=5
Q4. Documents say that with QoS Profiles applied to a WLAN, the AP may remark the LWAPP CoS value if the 802.1p value is higher than the Profile. Leaves the encapsulated DSCP the same yes?
Q5. If the AP is not configured for WMM, what queuing does it use? WMM uses EDCF right?
Q6. All four WMM queues seem like Strict Priority queues, where each queue will be fully served before a lower priority queue.
jamesshen
Frequent Visitor
Frequent Visitor
Unanswered:
Q6. All four WMM queues seem like Strict Priority queues, where each queue will be fully served before a lower priority queue?
Answered:
>>1st, 802.1p is ignored from SW-->WLC, only DSCP mapped
>>yes, but only if it is greater
>>yes DSCP stays same, it is only a ceiling for 802.1p/e
