Client can not connect to AP AIR-AP1252AG-T-K9 + Controller AIR-WLC2112-K9 + external dhcp server
Rosa Ladeira
DHCP server offers IPs in range 147.65.105.xxx to clients and in this case client connects with IP 10.42.43.1
AP #show dhcp lease
Temp IP addr: 147.65.106.31  for peer on Interface: GigabitEthernet0
Temp  sub net mask: 255.255.255.0
   DHCP Lease server: 147.65.1.83, state: 3 Bound
   DHCP transaction id: 146C
   Lease: 1800 secs,  Renewal: 900 secs,  Rebind: 1575 secs
Temp default-gateway addr: 147.65.106.254
   Next timer fires after: 00:03:18
   Retry count: 0   Client-ID: 588d.095e.6e9c
   Client-ID hex dump: 588D095E6E9C
   Hostname: AP
(Cisco Controller) show>client detail 00:1b:77:a4:b8:74
Client MAC Address............................... 00:1b:77:a4:b8:74
Client Username ................................. N/A
AP MAC Address................................... c4:71:fe:5b:80:50
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 3
BSSID............................................ c4:71:fe:5b:80:52
Connected For ................................... 1280 secs
Channel.......................................... 1
IP Address....................................... 10.42.43.1
Association Id................................... 1
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Session Timeout.................................. 1800
Client CCX version............................... No CCX support
QoS Level........................................ Silver
Diff Serv Code Point (DSCP)...................... disabled
802.1P Priority Tag.............................. disabled
WMM Support...................................... Enabled
U-APSD Support................................... Disabled
Power Save....................................... OFF
Current Rate..................................... 54.0
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
ACL Name......................................... none
ACL Applied Status............................... Unavailable
Policy Type...................................... WPA2
Authentication Key Management.................... PSK
Encryption Cipher................................ CCMP (AES)
Management Frame Protection...................... No
EAP Type......................................... Unknown
Interface........................................ wirelessusers
VLAN............................................. 105
Quarantine VLAN.................................. 0
Access VLAN...................................... 105
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 1
      Fast BSS Transition........................ Not implemented
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 3622
      Number of Bytes Sent....................... 823
      Number of Packets Received................. 18
      Number of Packets Sent..................... 5
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Key Msg Timeouts............. 2
      Number of Data Retries..................... 7
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 20
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -91 dBm
      Signal to Noise Ratio...................... 5 dB
Nearby AP Statistics:
      AP(slot 0) .........................
antenna0: 21 seconds ago -95 dBm................. antenna1: 21 seconds ago -90 dBm
(Cisco Controller) >show tech-support
---------------Show boot---------------
Primary Boot Image............................... 6.0.199.4 (active)
Backup Boot Image................................ 6.0.199.4
---------------show time---------------
Time............................................. Wed Aug  3 21:20:41 2011
---------------Show Inventory---------------
System Inventory
Burned-in MAC Address............................ F8:66:F2:63:0F:00
---------------Show udi---------------
NAME: "Chassis"    , DESCR: "Cisco Wireless Controller"
PID: AIR-WLC2112-K9,  VID: V05,  SN: JMX1446Z1GU
---------------Show sysinfo---------------
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 6.0.199.4
RTOS Version..................................... 6.0.199.4
Bootloader Version............................... 4.0.191.0
Emergency Image Version.......................... 6.0.199.4
Build Type....................................... DATA + WPS
System Name...................................... impa-wireless4
System Location.................................. sala 102
System Contact................................... netadm@impa.br
System ObjectID.................................. 1.3.6.1.4.1.9.1.828
IP Address....................................... 147.65.14.241
System Up Time................................... 1 days 2 hrs 43 mins 4 secs
System Timezone Location.........................
Configured Country............................... BR  - Brazil
--More-- or (q)uit:-7. excessive failed login attempts.
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +36 C
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 3
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 0
---------------Show Interface ---------------
Interface Configuration
Interface Name................................... ap-manager
MAC Address...................................... f8:66:f2:63:0f:00
IP Address....................................... 147.65.106.4
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 147.65.106.254
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 106
--More-- or (q)uit
Physical Port.................................... 1
Primary DHCP Server.............................. Unconfigured
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
Interface Name................................... management
IP Gateway....................................... 147.65.14.7
VLAN............................................. 14
Quarantine-vlan.................................. 0
AP Manager....................................... No
--More-- or (q)uit
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
Interface Name................................... wirelessusers
IP Address....................................... 147.65.105.4
IP Gateway....................................... 147.65.105.254
---------------Show port summary---------------
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       100 Full   Up     Enable  N/A
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
5  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
6  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
7  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
8  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
--More-- or (q)uit
Client Statistics:
Leo Laohoo
Upgrade your WLC to 7.0.116.0.  I've read somewhere about DHCP issues with 6.X,
Thanks.
Rosa
