LAP - Bandwidth issue
Hello everyone,
I would like to share with you a strange issue.
After a WLC upgrade (version 6 to 7), we noticed that the bandwidth had been reduced by twice.
The only workaround we found to restore the bandwidth is a reset of the LAP to factory default.
Does anyone have already seen something like that ?
7 Replies 7
Scott Fella
What actual code did you upgrade to? Usually I would stick with the latest from each version.
-Scott
Upgrade from 6.0.199 to 7.0.230.
Try 7.0.235.3
-Scott
Unfortunately I wasn't able to find any bug ID matching my issue fixed in 7.0.235.3.
Scott Fella
Is there a bug id for your issue now? I have never ran into the issue you are saying. How are you testing.
-Scott
- Is there a bug id for your issue now?
I don't think so.
- How are you testing?
Wtih ftp transfers (5 Mbps before reset to factory / 15 Mbps after reset to factory)
You should open a TAC case and see if they have a bug id or maybe they will create one if they can reproduce it. Then follow up on your post if possible.
-Scott
