LAP1041 LED off
minwangaip
Community Member
I have two LAP1041 with WLC2504 everything works fine. But since yesterday when it boots up it flashes green, then solid green, then after about 10 seconds the green LED turns off, however the LAP is still working fine, Why is that?  If I put my eyeball up close to the LED I see dim red inside the LED plastic cover.
Scott Fella
On the WLC CLI issue: config ap led-state enable all
-Scott
worked! thank you!
No problem!
-Scott
