07-13-2015 01:41 AM - edited 07-05-2021 03:33 AM
Hello All
I have a WLC and there were 4 APs already registered to it.
Suddely they have started having problems where in it is not registering to the WLC anymore although they are getting the correct IP address and I can ping these IP addreses
%Error opening flash:/c1240-rcvk9w8-mx/info (No such file or directory)cisco AIR -LAP1242AG-E-K9 (PowerPCElvis) processor (revision A0) with 27638K/5120K bytes o f memory.
Also saying its flashing amber and.
Has the IOS got corrupted, will a factory reset fix it?
07-13-2015 02:04 AM
Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time;
3. AP: sh version; and
4. AP: sh ip interface brief
07-13-2015 02:32 AM
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.120.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... rn-lagos-wlc01
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 172.28.115.13
Last Reset....................................... Power on reset
System Up Time................................... 0 days 1 hrs 55 mins 13 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... GB - United Kingdom
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +28 C
External Temperature............................. +32 C
Fan Status....................................... 3800 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 0
Burned-in MAC Address............................ CC:D8:C1:40:B0:A0
Maximum number of APs supported.................. 15
(Cisco Controller) >show time
Time............................................. Sat Jan 1 02:03:12 2000
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server NTP Msg Auth Status
I do not have access to the APs that is why I cannot see those details but trying to arrange someone locally to do it..
07-13-2015 02:46 AM
Time and date of the WLC is wrong. Configure NTP. If the time and date are wrong, the APs won't join.
