Large ping packets in wireless network
gchongkc
Community Member
In a wireless environment, what is the maximum ping packet size I can use together with multiple section of ping command. For example:
I used multiple section of the following command.
Ping 10.10.10.10 –t –l 10000
I also try multiple section of ping command with different packets size simultanously.
Ping 10.10.10.10 –t –l 30000 and Ping 10.10.10.10 –t –l 10000 and Ping 10.10.10.10 –t –l 20000
With such packet size, should this create any problem in a wireless environment????
I dont think you will get any problems with large pings but you get problems in wlan enviroment if you have smallpackets! try iperf. the performance will decrease dramaticlly. the br1300 have a feature called packet concentation with that small packets are "come together" to larger packets.
bernhard
