leap issues
simon.thompson
Frequent Visitor
Frequent Visitor
I have had an issue with neatwork eap configured on the AP with Encryption mode wep mandatory. Not all clients could eap authenticate but some could. The rest would only authenticate when the broadcast wep key was entered in slot1. Has anyone else come across this issue
b.hsu
Level 11
Level 11
I think it might be problem with some level in the communication between the AP and the authentication server. Verify that you can ping from the Access Point (AP) to the server. For more information, refer to the Performing Pings and Link Tests section of Cisco Aironet 1200 Series Network Management. Check your network to make sure that traffic between the two devices is not blocked by any intervening firewall or traffic filters. If there is good IP connectivity, reset the shared keys (shared secrets) on the AP and the server to ensure they match.
