Led AP1130
ricardorojas123
Level 7
Level 7
I connect a LAP1131 to power injector and its led status change to amber? what means this? The AP is registered in the wireless lan controllers but its Operational status is Down. I selected the "power injector states" check box.
Adam Watts
Level 2
Level 2
not sure if this will help, but assuming the ap's are plugged into a cisco switch you have to turn CDP off on the ports you are using.
i had a similar problem with a group of 1242's i had on older cisco switches. turned cdp off and it worked fine.
Adam Watts
Level 2
Level 2
