Licenses issue
Torken
Level 3
Level 3
I am having a problem with cisco smart software manager. Every day I receive an email :
Insufficient Licenses - The Virtual Account "DEFAULT" has a shortage of "Aironet DNA Advantage Term Licenses" licenses. 6 licenses are required to return to compliance.
Insufficient Licenses - The Virtual Account "DEFAULT" has a shortage of "AP Perpetual Networkstack Advantage" licenses. 6 licenses are required to return to compliance.
I have 7 ap with 1 EWC
When I go on the admin webpage of the EWC I got the "Authorization Status" set to "OUT OF COMPLIANCE"
FYI, EWC have internet access for Cisco smart software manager
AP : Cisco Catalyst 9115AXI
IOS :
Cisco IOS XE Software, Version 16.12.04a
Cisco IOS Software [Gibraltar], C9800-AP Software (C9800-AP-K9_IOSXE-UNIVERSALK9-M), Version 16.12.4a, RELEASE SOFTWARE (fc1)
Rich R
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/nb-o6-embded-wrls-cont-ds-cte-en.html#Licensing
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/q-and-a-c67-743152.html#Licensingandordering
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215635-licensing-on-9800-wireless-lan-controlle.html#anc20
So if you're using it as standalone EWC (no DNAC) then licenses are not required but if the EWC is integrated with DNAC then you do require licenses for each/every AP.  Maybe you've configured something for DNAC on the EWC or maybe a bug in that old software.
From Amsterdam-17.3.2.a and Bengaluru-17.4.1 they've implemented the new Smart Licensing Using Policy licensing model
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/config-guide/b_wl_17_3_cg/m-sl-using-policy.html
so consider moving to that.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
