Licensing regarding AIR-CT2504-5-K9 controller
atifali.zaidi1
Hello Experts ,
i would like to know about the part number AIR-CT2504-5-K9 which is for the 2500 series controller, the description says "2504 Wireless Controller with 5 AP Licenses".   does this mean that it will  come with the ap licenses pre-installed in it and we just need to get it activated ?
OR
we would need to contact cisco to get the PAK keys for the licesnes to get it installed on the WLC ?
LJ Gabrillo
Level 5
Level 5
As per our experience ordering that type of model for many of our clients, the 5 AP license is already pre-loaded.
Also, just a heads on up licenses in general, you do not need to "contact" Cisco for the PAK Key, the PAK key/documentation comes with the box usually in a hard cardboard envelope. In rare cases it is sent in PDF form, it's often not directly sent to you(client), but to your distributor/systems integrator from where you bought it. Make sure to ask them if you bought additional licenses.
Hope this helps :D
LJ Gabrillo
Level 5
Level 5
Hope this helps :D
