limit clients per ap in autonomous system
Srin_G
Level 3
Level 3
is there anyway we can limit clients per ap in auto. system? apart from adding mac-addresses in the AP?
Scott Fella
Not really...besides mac filter:(
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Amjad Abdullah
You can limit per SSID:
AP(config-ssid)# max-associations 15
The above example allows for 15 clients only to connect to the SSID. Change the number as you need.
Amjad
Rating useful replies is more useful than saying "Thank you"
