Limit connection for one access point with WLC
Foo Chuan Soon
Is there possible to limit number of users connect to certain ap? For example i have an ap named ap123 that will allowed maximum 30 users connected (not using mac filtering) in WLC.
Leo Laohoo
I don't think this is doable.
If you want to do this to one AP then convert it to autonomous.
Andrew Betz
Hi there,
There is currently no method to set a hard client count for a lightweight APs, however you may be able to leverage Aggressive Load Balancing on the WLAN to achieve similar results.
