Limited error connectivity message on Wireless
akash04lingam
Level 3
Level 3
While connecting users to wireless connection getting Limited error connectivity message by using AP1142N with H-Reap solution. The user is able to connect without any problem with other buidling AP with same solution.Please let me know....what could be the problem ?
Nicolas Darchis
That means the clients did not receive an ip address or a proper gateway. I would suggest you check that and check your DHCP configuration.
HREAP requires a DHCP server to be present on the site where the HREAP AP is.
Thanks, you are correct but two more AP's connected to same switch & controller with same solution, there is no problem...it is only problem with one AP....I have applied the templates again & tested but same problem appeared.. Even switch port also changed.
Check the vlan mappings on that AP maybe ?
