Linux MPI350 driver problem
ralfw
Level 2
Level 2
Hi all,
I'm not sure if that's the right place to asked, but I have problems getting the
Linux driver for the minipci 350 wireless card to work under RedHat 9.0. I
compiled the driver as module and tried it under several recent kernels. I get
always a segmentation fault while the driver initializing.
Any help or hope to get a working driver for at least the standard RH9
kernel 2.4.20-xx ?
[root@t40p driver]# gcc mpi350.c -o mpi350.o -c
-I/usr/src/linux-2.4.20-18.9/include -O2 -D__KERNEL__
-DMODULE -Wall
[root@t40p driver]# insmod mpi350.o
Warning: loading mpi350.o will taint the kernel: no license
See http://www.tux.org/lkml/#export-tainted for information about
tainted modules
Segmentation fault
[root@t40p driver]# lsmod
Module Size Used by Tainted: P
mpi350 85472 1 (initializing)
Ralf
Not applicable
Downgrade your MPI350 card firmware to version you can find on cisco.com (5.00.03 for me). It's on the same page as the linux driver itself.
Jan "Pogo" Mynarik
Thanks ! Now it works.
R.Weidemann
