list wireless users?
2pat
Visitor
Hi, is there a way to get the same info as listed by the IOS command: show dot11 associations
using snmp under Linux? The closest I have found is: snmpwalk -v1 -c public 172.24.24.218 | grep RFC1213-MIB::atPhysAddress
Anyone?
Surendra BG
Here is the MIB to get the same..
CISCO-DOT11-ASSOCIATION-MIB
here is the details as well!!
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=cDot11ActiveWirelessClients&translate=Translate&submitValue=SUBMIT&submitClicked=true
Lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
good info .. did not know that +5
