LobbyAdmin WLAN not updated
gohgss2010
Community Member
I have lately created a new PEAP WLAN but it is not relected the option on Lobby Ambassador Guest Management.
Any idea on this?
Lobby Admin can manage accounts for web-authentication enabled wlans.
Try to create a wlan with layer 3 security enabled.
Normally if you login with your lobby admin account you should be able to create guest accounts for this wlan.
Hope this helps,
Regards.
I think I don't have any issue with the web-authentication enabled WLAN.
Can I conclude the lobby admin account just for web-authentication enabled WLAN guest administration?
That's right,Lobby admin can manage accounts only for web-authentication enabled WLANs.
