Location Applinace problem
steve.good
Community Member
Just unboxed a brand new location Applinace and following the setup steps. when I get to where I have to configure the ifcfg-eth0 file I put in all the changes and try to save and I get a E212: Can't open file for writing error message. I can not get it to work on either interface, I have RW permissions on the file. Does anyone have any suggestions, I am not famillar with redhat so will need detailed instructions of the commands if so be.
Steve Good
csthorne
Level 2
Level 2
it may have the file open. you might try "init 3" then see if you can edit. you can always try ,chmod 777 filename, but that's a bit overkill.
