Location Manager does not launch
john.sobrinho
Level 3
Level 3
Hi all..
Running WLSE 2.7.1 and have repeatedly uninstall / reinstall the java client, to no avail.
The Location Manager is able to detect that I am runing java but can not detect the version.
John
smalkeric
Level 11
Level 11
Check to see if multiple plugin vesions are installed on the same PC. You can go to Windows Control Panel > add/remove programs and remove all the pluggins. Then do a fresh installation of the required plug in.
