Logging of Associations and Disassociations on Local-Mode APs / C9800
rschroeder1006
when we used FlexConnect, all the APs logged every single association and disassociation of a client, i.e.:
%DOT11-6-ASSOC: Interface Dot11Radio0, Station aeda.0a63.xxxx REAP Associated KEY_MGMT[Open]
%DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station aeda.0a63.xxxx Sending station has left the BSS
In Local mode, this logging does not happen and even the controller does not log anything comparable.
I would like to log any association and disassociation of all wireless clients in the network while using Local mode APs. How is that possible with C9800 controllers? And is there a possibility for AireOS controllers too?
Robin
6 Replies 6
marce1000
                  - Could you try with logging trap debugging in the controller running-configuration ?
 M.
this does not help, unfortunately. But thanks for the suggesstion.
Robin
I know about radio active traces but they don't run all the time for every possible wireless client. I would like to know where my wireless clients are. This was possible with FlexConnect and in early times without controllers by simply looking at the AP logs.
rschroeder1006
I will try using SNMP traps for that as soon as I have some spare time for it - and share the results.
rschroeder1006
...and here is the solution: SNMP traps that will be sent to syslog with the help of a trap handler script.
First, install a SNMP trap receiver (Net-SNMP) with the following configuration (snmptrapd.conf) on your syslog server:
disableAuthorization yes
format1 %.4y-%.2m-%.2l %.2h:%.2j:%.2k %B [%.4Y-%.2M-%.2L %.2H:%.2J:%.2K] %v\n
format2 %.4y-%.2m-%.2l %.2h:%.2j:%.2k %B [%.4Y-%.2M-%.2L %.2H:%.2J:%.2K] %v\n
traphandle 1.3.6.1.4.1.14179.2.6.3.53 /usr/local/bin/traphandle.pl
traphandle 1.3.6.1.4.1.14179.2.6.3.1 /usr/local/bin/traphandle.pl
Then, create the trap handler script /usr/local/bin/traphandle.pl:
#!/usr/local/bin/perl
use strict;
use warnings;
use Sys::Syslog qw(:standard :macros);
my $data = {};
my $reason = {
'1' => 'unspecified',
'2' => 'previousAuthNotValid',
'3' => 'deauthenticationLeaving',
'4' => 'disassociationDueToInactivity',
'5' => 'disassociationAPBusy',
'6' => 'class2FrameFromNonAuthStation',
'7' => 'class2FrameFromNonAssStation',
'8' => 'disassociationStaHasLeft',
'9' => 'staReqAssociationWithoutAuth',
'40' => 'invalidInformationElement',
'41' => 'groupCipherInvalid',
'42' => 'unicastCipherInvalid',
'43' => 'akmpInvalid',
'44' => 'unsupportedRsnVersion',
'45' => 'invalidRsnIeCapabilities',
'46' => 'cipherSuiteRejected',
'99' => 'missingReasonCode',
'101' => 'maxAssociatedClientsReached',
'200' => 'unSpecifiedQosFailure',
'201' => 'qosPolicyMismatch',
'202' => 'inSufficientBandwidth',
'203' => 'inValidQosParams',
while (<>) {
$data->{'type'} = 'Association' if /^SNMPv2-MIB::snmpTrapOID\.0 SNMPv2-SMI::enterprises\.14179\.2\.6\.3\.53$/;
$data->{'type'} = 'Disassociation' if /^SNMPv2-MIB::snmpTrapOID\.0 SNMPv2-SMI::enterprises\.14179\.2\.6\.3\.1$/;
$data->{'source'} = $1, next if /^([^\.\s]*)\S*$/;
$data->{'AP'} = $1, next if /^SNMPv2-SMI::enterprises\.14179\.2\.2\.1\.1\.3\.[^\s]* "([^"]*)"$/;
$data->{'MAC'} = lc("$1:$2:$3:$4:$5:$6"), next if /^SNMPv2-SMI::enterprises\.14179\.2\.6\.2\.34\.0 "(..) (..) (..) (..) (..) (..) ?"$/;
$data->{'BSSID'} = lc("$1$2.$3$4.$5$6"), next if /^SNMPv2-SMI::enterprises\.14179\.2\.6\.2\.35\.0 "(..) (..) (..) (..) (..) (..) ?"$/;
$data->{'slot'} = $1, next if /^SNMPv2-SMI::enterprises\.14179\.2\.6\.2\.36\.0 (\d+)$/;
$data->{'reason'} = "Reason:$1/$reason->{$1}", next if /^SNMPv2-SMI::enterprises\.14179\.2\.6\.2\.37\.0 (\d+)$/;
$data->{'user'} = $1, next if /^SNMPv2-SMI::enterprises\.14179\.2\.6\.2\.39\.0 "([^"]*)"$/;
$data->{'IP'} = $1, next if /^SNMPv2-SMI::enterprises\.14179\.2\.6\.2\.43\.0 (.*)$/;
openlog('WLAN-Assoc', 'pid', LOG_LOCAL0);
syslog(LOG_INFO,
join(" ",
"Src:$data->{'source'}",
"Type:$data->{'type'}",
"Client:$data->{'MAC'}",
"AP:$data->{'AP'}",
"BSSID:$data->{'BSSID'}",
"Slot:$data->{'slot'}",
"IP:$data->{'IP'}",
"User:$data->{'user'}",
$data->{'reason'},
closelog();
Finally, do a chmod +x /usr/local/bin/traphandle.pl to make the script executable.
You can chech the syntax with perl -c /usr/local/bin/traphandle.pl
On the 9800 series controllers, configure the following to enable the respective SNMP traps additionally to the already existing SNMP configuration:
snmp-server host <ip-address> version 2c public
trapflags client dot11 associate
trapflags client dot11 disassociate
From now on, Associations and Disassociations will be logged into syslog on the syslog server, i.e.:
WLAN-Assoc[16649] Src:wlc-3 Type:Association Client:9e:de:29:xx:xx:xx AP:ap-hzo-3 BSSID:7010.5cxx.xxxx Slot:0 IP:0.0.0.0 User:<username>
WLAN-Assoc[16650] Src:wlc-3 Type:Disassociation Client:66:2f:7a:xx:xx:xx AP:ap-hma20-1 BSSID:544a.00xx.xxxx Slot:1 IP:x.x.x.x User:<username> Reason:1/unspecified
Have fun.
Robin
