01-02-2023 08:42 AM
Anyone can help out what is the login and password for this access point
loading up capwap....then nothing
i try all password none working
/ factory reset done/
01-02-2023 08:54 AM
post a complete boot log here to see what is wrong. (is this AP registering with WLC ? - or isolated network)
if you reset it correctly Cisco/Cisco should work
same as below for reset to factory :
07-31-2024 03:45 AM
Hi @balaji.bandi I have the same issue. My AP is trying to discover for CAPWAP. I need to convert it into Autonomous. Whats next???
