lost connection on lan controller 2106
mavega2005
Community Member
hi,
I have problem with access point air-lap1242ag-a-k9 work with lan controller air-wlc2106-k9.
the connection works well during a time but soon it is lost during few minutes and soon it raises automatic, this process repeats the day throughout. I have seen that valor AP ID in the LAN controller changes when this happens.
thanks for the aid
Marcos.
jeromehenry_2
Level 7
Level 7
Hi Marcos,
So are you saying that the AP disapears from the controller for a little while, then comes back?
Are the APs in the same subnet as the management/ AP manager interfaces? I would do a debug lwapp events enable and check how many broadcast sources you have in this subnet. It happens that when there are too many sources of broadcast, APs get disconnected; isolating the APs in another subnet/VLAN usually solves the issue.
Tx
Jerome
