Lost The Cisco Aironet 1310 Web Interface????
datencio1
I've been having connection issues with my (2) Aironet 1310, which are setup in a bridge p2p mode.  A few weeks ago we had a power outage due to a lighting storm.  Well, it knocked out my non-root bridge (not connecting to the root).  So I brought it back to check the configurations, but when I try to use the web console all I get is the following page:
When I click the "Web Console" link it takes me to the following page:
Is there a way to get the original web console page back?
WOW!! thats great to hear... i tot the same and that y asked u whether we reloaded the Bridge in my first post....
Anyways, it was my pleasure working with you.
Have a great day
Surendra
Surendra BG
15 Replies 15
Surendra BG
tried rebooting the device?? wat about the console access?
Surendra
Surendra BG
Thanks for the reply, but no luck in the console.  I tried doing the hard reset with the "erase nvram" option, but it kept telling me that it was a bad command.  I finally got some soft resets done through the CLI, but still same page w/ no access to the default web console.  Any Ideas would help!!!
Sorry for the delayed response.. What does the command "sh ip int br" output say from the CLI or the Console access??
Surendra
Surendra BG
Hello Surendra,
It reads as follows:
Ineterface               IP-Address               OK?              Method               Status                         Protocol
BVI1                      10.1.254.101             YES             other                   up                              up
Dot11Radio0           unassigned               YES             unset                  administratively down   down
FAstEthernet0        unassigned                YES             other                  up                              up
Daniel
are we able to get the wireless access if we configure the same with CLI??
Surendra
Surendra BG
Okay, I got it  working.  I had to reload the IOS, it must have got corrupted.  Again, thanks for you help.
Have a great day
Surendra
Surendra BG
Looks like i faced same problem here. May i know how to reload back the IOS, if used console, what command need to key in? Im totally new to this Cisco system. Can we do something from the web error (webpage is attach) using any command? Please help.
Thank You..
Please continue with your post.. anyways...
here is the command on the CLI..
archive download-sw / force-reload /overwrite tftp:///
Lemme know how this answered your question..
Surendra
Surendra BG
Ok,
Thank you, i will try this morning..
lemme know how the upgrade goes..and lemme know if this answered your question..
Surendra
Surendra BG
Ok, itry my best. Thank you
On Tue, Nov 23, 2010 at 10:08 AM, surbg <
How to insert IMAGE.Tar? on my desktop, i have 2 image file for software update.c1310-k9w7-tar.124-3g.JA1 and c1310-k9w7-tar.124-21a.JA1. How to select either one? Please help.Thanks you
