11-22-2010 10:15 AM - edited 07-03-2021 07:27 PM
We have a couple of APs that do not show the Vlans and SSIDs through the AP web interface. If you go to the SSID manager page in web interface, the page comes up but does not show any of the SSIDs configured. The same goes for Services - Vlan. That page comes up but does not show any Vlans configured. If you telnet to the APs, you see the listed mssid and all the SSID interfaces. The SSIDs on the APs are functional and working. This just makes it difficult to use the web interface for these APs. I have tried to compare running configs on APs where web interface is not showing this and on APs that it is showing but cannot see any differences.
Thanks.
Solved! Go to Solution.
11-22-2010 10:51 AM
11-22-2010 11:43 AM
Well you have the point. What software is it running ? Is firefox supported on that version ? Maybe a bug on that version ?
Nicolas
11-22-2010 10:51 AM
Did you try with different web browsers ?
Nicolas
11-22-2010 11:39 AM
They APs in question view properly in IE but not Firefox.
All other APs view properly in Firefox. Not sure of all the IOS versions of APs. Should be 12.3 or 12.4.
Thanks.
11-22-2010 11:43 AM
Nicolas
11-23-2010 07:47 AM
We have IOS 12.4 (10b) JDA3 on the APs in question. I don’t see anything that states it does not have support for Firefox.
I do see that IOS 12.4 (21a) JA1 does have support for Firefox.
I will look at trying to upgrade these APs.
Thanks.
11-23-2010 10:44 PM
Unsupported things are never documented. You can't possibly list all browsers that you don't support.
But if it's not mentionned clearly as supported then it means "it might work but we never tested with it".
Let us know how it goes with the 12.4.21
Nicolas
Don't forget to rate answers that you find useful
