06-23-2016 04:41 AM - edited 07-05-2021 05:17 AM
Hi.. I have setup two autonomous access points with same SSID but on different channel(channel 6 & 11). users are complaining that they get low signal(1 or 2 bars out of 5) though they are nearly 3-4 mtrs away from AP.
I am not sure if there is any other configuration to amplify signal strength, please suggest some solution.
Both APs are running standalone(not on bridge or repeater mode).
06-23-2016 05:02 AM
Check the power level on AP!! and try to change it.
Read this doc, it may help:
https://supportforums.cisco.com/document/50526/how-configure-and-verify-transmitted-power-level-aps
Dont forget to rate helpful posts
06-23-2016 09:28 PM
Hi Sandeep,. I will check the power level on AP and get back.
HI George..Access point model - 4410N
06-23-2016 05:30 AM
What model access points ?
