Low wireless speed cisco air-cap1702i-e-k9 d
poratnir
So i had a tough time defining the AP settings cisco air-cap1702i-e-k9 d,
I managed to set 2.4Ghz and 5Ghz wireless networks
the only issue that speed is extremely low ,
I have on my direct wifi connection 200MB while in Cisco net barely 25MB in 5GHz and 34MG at 2.4Ghz...
what is the issue ?
Rasika Nayanajith
Without your configuration or additional details, cannot kay exactly why you experience slow performance. At minimum provide below output to see
AAP1#sho dot11 associations <client_mac_addr>
I would look for the following to begin with.
1. Configured channel width on 5GHz radio
2. Make sure AES encryption enable (not TKIP)
3. WMM is enabled
4. No other APs nearby operate on same channel
5. Client capability (spatial stream, 11n/11ac)
There are many posts on the cisco community talk about this issue, pls go through some of them listed below.
https://community.cisco.com/t5/wireless/autonomous-3500i-slow-speeds/td-p/4073821
https://community.cisco.com/t5/wireless/aironet-1602i-standalone-slow-transfer-speed/td-p/2491665
https://community.cisco.com/t5/wireless/slow-speed-between-two-3602-access-points-configured-as/m-p/3709295
Rasika
*** Pls rate all useful responses ***
