Aironet 1602i Standalone Slow Transfer Speed
rustydusty1717
Recently purchased 3 of these units and have them working fine, however I am receiving terribly slow transfer speeds from any server, or storage device I try to send or receieve. Fastest I can get is 2.5MB/s or 20Mb/s on all three. Very basic setup with broadcasting a single SSID on each with WP2 AES, using channels 11, 6 and 1 across the three. Brand new building, no other buildings near to cause interference with.
9 Replies 9
Sandeep Choudhary
Paste the out put of the commands:
sh wlan <wlan id>
also paste the conifg where wlc and AP connected to switch.
which type of access point are you using ???
Sorry to dig up an old topic but this problem is still happening. I have just ordered an additional one of these as our wireless continues to grow, which it should have the latest firmware so we will see if that helps.
Here is the latest config on one of them:
! Last configuration change at 16:57:56 -0700 Fri Mar 27 2015
! NVRAM config last updated at 16:58:14 -0700 Fri Mar 27 2015
version 15.2
no service pad
service password-encryption
hostname ap1
logging rate-limit console 9
enable secret 5 $1$0O/f$3da6LZAT28Go5ga8WYIbv0
no aaa new-model
clock timezone -0700 -7 0
no ip routing
no ip cef
ip domain name ad.digitex.ca
ip name-server 192.168.1.20
dot11 syslog
dot11 ssid Digitex-Canada
   authentication open
   authentication key-management wpa version 2
   guest-mode
   infrastructure-ssid optional
   wpa-psk ascii 7 02522B08582956721F6E5D5844
username Cisco password 7 123A0C041104
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 ssid Digitex-Canada
 antenna gain 0
 stbc
 beamform ofdm
 channel 2462
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address 192.168.1.38 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.1.6
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
sntp server 64.4.10.33
sntp broadcast client
end
I'm having this issue as well, and we have 5 1602i series APs in autonomous mode.
I tried setting the 5 GHz radio to 40-above as suggested, but the AP was unaffected.
I factory reset an AP and tested it again with 15.2.4-JB6 IOS and it gets expected throughput without any Encryption.
I then enabled Encryption as AES CCMP and turned on WPAv2 as mandatory.  The throughput immediately dropped to roughly 4 Mbps each direction.
I upgraded to 15.3.3-JAB, which is the latest firmware.  I factory reset the AP again and got expected throughput.  Then I enabled Encryption and turned on WPAv2 and the same drop happened.
I tried to just do a basic 40-bit WEP key, and even that killed the throughput.
It seems to be isolated to the Encryption and SSID security, but I have no idea what's causing it.
Update: IOS ver 15.2.2.JB2 seems to work fine with Encryption.
Scott Fella
I have clients that are also experiencing slowness with these 1602's. I'm waiting to see what TAC comes up with to be honest. I have tested this in a lab and it's fine, but maybe it's an issue when you have a bunch of these.... Who knows.
-Scott
Scott Fella
Disable WMM and try again. If that helps, then inwouldnopen a TAC case.
-Scott
rustydusty1717
Still having the issue. Here's the config file:
no service pad
hostname ap1
no aaa new-model
no ip routing
no ip cef
dot11 syslog
dot11 ssid DC
   authentication open
   guest-mode
   wpa-psk ascii 7 1546245F570572777B1361
bridge irb
no ip address
no ip route-cache
ssid Digitex Canada
antenna gain 0
stbc
beamform ofdm
channel 2462
station-role root
bridge-group 1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
is there any reason why you have shutdown radio1 (5GHz) ? if you want higher throughput you have to use 5GHz band with channel bonding (40MHz). Something similar below under radio1 would do it.
 ssid Digitex Canada
 channel width 40-above
 no shut
Then if you clients are capable of 5GHz will get benefits. Below chart give data rates you can get depend on spatial streams client could support & CH Bandwidth.
MCS
Post "show dot11 associations <client_MAC>" output once you do this to see what data rate client get associated
Rasika
**** Pls rate all useful responses ****
abwahid
Level 4
Level 4
As Access-point 1602i support 'b/g/n' for 2.4GHz and which is definitely backward compatible with the b-clients, so you need to make sure your client should be in 'b/g/n' or in 'n' only mode to get better through put
and before taking the throughput reading check the connection speed at your client device.
