LWAP issues with a 5508 controller after AP upgrade
martynch1
Hi All, I’m having a few problems after upgrading my AP to a LWAP and hope you can help.
I have an AIR-AP1242AG-E-K9 which had c1240-k9w8-mx.124-21a.JA loaded, I followed the link below and upgraded with Cisco’s upgrade tool to c1240-rcvk9w8-mx with no problems at all, after the upgrade I could then see the LWAP on the 4402 controller and had it working a treat.
Now the problems begin, I brought it into the office where we have 5508 controllers, plug in the LWAP into our management switch and boot it up I get an IP assigned from the DHCP server and the AP goes into discovery mode but never finds the controller.
I have logged the boot process but this does not give much away, our other 1100 series AP’s boot fine, I was hoping that somebody here could help me resolve this issue.
Link to upgrade material.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp169977
Console Boot Log.
Xmodem file system is available.
flashfs[0]: 9 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 6848512
flashfs[0]: Bytes available: 9150464
flashfs[0]: flashfs fsck took 36 seconds.
Base ethernet MAC Address: 00:1d:45:01:03:0a
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"...##################################################################################################################################################################################################
File "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
             Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.4(10b)JDA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 30-Oct-08 12:05 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x003C24A0
Initializing flashfs...
flashfs[1]: 9 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 6848512
flashfs[1]: Bytes available: 9150464
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1242AG-E-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1131825Y
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1D:45:01:03:0A
Part Number                         : 73-10256-06
PCA Assembly Number                 : 800-26918-05
PCA Revision Number                 : A0
PCB Serial Number                   : FOC11296730
Top Assembly Part Number             : 800-29233-01
Top Assembly Serial Number           : FCZ1131825Y
Top Revision Number                 : A0
Product/Model Number                 : AIR-AP1242AG-E-K9
The name for the keys will be: ap.cisco.com
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
ip ssh version 2
% Invalid input detected at '^' marker.
transport input ssh
aaa new-model
aaa authentication login default enable local none
o
Press RETURN to get started!
*Mar 1 00:00:08.640: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar 1 00:00:09.675: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar 1 00:00:12.131: %SYS-5-RESTART: System restarted --
transport input ssh
logging origin-id string AP:001d.4501.030a
logging 255.255.255.255
logging trap 3
*Mar 1 00:00:28.149: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:28.627: Logging LWAPP message to 255.255.255.255.
%DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 172.30.156.66, mask 255.255.255.224, hostname AP001d.4501.030a
Translating "CISCO-LWAPP-CONTROLLER. somedomain.com "...domain server (172.22.7.22)
%LWAPP-3-CLIENTEVENTLOG: Did not get vendor specific options from DHCP.
%LWAPP-3-CLIENTEVENTLOG: Did not get log server settings from DHCP.
%CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source (172.22.7.23)
%LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CISCO-LWAPP-CONTROLLER. somedomain.com
%LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolve CISCO-LWAPP-CONTROLLER.somedomain.com
And that is where she sits and does nothing more, I have noticed the DNS problems but the other 1100 series LWAP’s boot up after show that same issue.
martynch1
Its OK I have now sotred it, I was missing hte option 43 on the DHCP server, it was there for the 1100 series but not the 1200 series
Thanks anyway
Jeffrey Keown
If new ap's arent on the same subnet as the controller's management interface, you've got to 'tell' them how initially find the controller.
Dns and dhcp option 43 are the most common methods:
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml#backinfo
