WLAPP is a solution offered to have a centralized management, that means that you cannot access the AP directely to configure it, but you need a WLC (Wireless LAN Controller). It's expensive as a solution but benefic if you have a big number of APs to manage.
You can find on the Cisco website about Unified Wireless Solution, it used LWAPP
PLEASE RATE IF THAT HELP
