LWAPP AP1232 not able to join Controller
stephan.meier
After AP1232 convertion from IOS to LWAPP -> following error Message
*Mar 1 00:00:44.216: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar 1 00:00:50.217: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the Join response
*Mar 1 00:00:50.217: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
*Mar 1 00:00:50.249: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN RESPONSE.
*Mar 1 00:00:50.249: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file system is available.
Rob Huffman
Hi Stephan,
This is a pretty common problem that is usually associated with one of 2 things;
1. The time setting on the WLC and the PC running the upgrade tool (must be in sync).
2. A problem with the SSC (Self Signed Certificate).
Have a look at these great threads from earlier this year that provide answers to both problems. Perhaps you could also let us know what WLC Model and what version you are running.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddb4d26
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=Getting%20Started%20with%20Wireless&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddaba5b
Hope this helps!
Rob
Please remember to rate helpful posts.....
Hi Rob,
Thanks for your information will check it and come back to you....
HW: WLC-4402
SW: AIR-WLC4400-K9-4-0-179-8.aes
Greets
Stephan
