MAC Authentication does not work
gilmo
Level 2
Level 2
My MAC Authentication does not work.
I have a ACS 3.0 server set. the MAC address is set in the user name field and in the password field.
I can ping the ACS, I can ping my AP, I can ping my client.
I don't want WEP and I don't want LEAP just MAC. So I set my authentication to "Open with MAC" My client has WEP set to NO WEP and authentication to OPEN
I have the latest drivers for both AP and my 350 Client.
I see that the client is associating and disassociating back and forth non stop. My AP log is full with the following message:
Station 0009.7c9f.xxxx Authentication failed
this is my config:
version 12.2
no service pad
service password-encryption
hostname GOM_1200IOS
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
server 10.1.2.197 auth-port 1812 acct-port 1812
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius wlccp_rad_infra
aaa group server radius wlccp_rad_eap
aaa group server radius wlccp_rad_leap
aaa group server radius wlccp_rad_mac
aaa group server radius wlccp_rad_any
aaa group server radius wlccp_rad_acct
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login wlccp_infra group wlccp_rad_infra
aaa authentication login wlccp_eap_client group wlccp_rad_eap
aaa authentication login wlccp_leap_client group wlccp_rad_leap
aaa authentication login wlccp_mac_client group wlccp_rad_mac
aaa authentication login wlccp_any_client group wlccp_rad_any
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa accounting network wlccp_acct_client start-stop group wlccp_rad_acct
aaa session-id common
enable secret xxxxxx
username Cisco password xxxx
ip subnet-zero
iapp standby timeout 5
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 9DF1C10BF11A transmit-key
ssid GOM_1230
authentication open mac-address mac_methods
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2312
channel 2462
station-role root
no cdp enable
dot1x reauth-period server
dot1x client-timeout 600
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 1
interface BVI1
ip address 172.16.43.45 255.255.240.0
no ip route-cache
ip default-gateway 172.16.47.254
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
ip radius source-interface BVI1
access-list 700 permit 000a.b74c.e8c9 0000.0000.0000
access-list 700 permit 0009.7c9f.d6e0 0000.0000.0000
access-list 700 permit 0006.25b1.2f79 0000.0000.0000
access-list 700 permit 000a.b78b.2d19 0000.0000.0000
access-list 700 permit 000b.5f6e.77c8 0000.0000.0000
access-list 700 deny 0000.0000.0000 ffff.ffff.ffff
access-list 701 deny 000b.5f6e.77c8 0000.0000.0000
access-list 701 permit 0000.0000.0000 ffff.ffff.ffff
no cdp run
snmp-server community GOM_AP1230 RO
snmp-server enable traps tty
radius-server local
group AP1230
user brazil nthash 7 1249523544595F517972017912677A3055325A25770B08770D5C5B4E4478087605 group AP1230
radius-server host 10.1.2.197 auth-port 1812 acct-port 1812 key 7 00233C2B
radius-server retransmit 3
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 5 15
end
What is wrong?
Thanks very much for your help.
gilmo
Level 2
Level 2
I figured out what was wrong so thank you for stopping by.
I will publish the config for other people to see.
coolccnp
Community Member
so what was wrong?
