Bookmark
Subscribe
2744
Macro and micro cells on 2800 and 3800
aleopoldie
Level 3
Level 3
I read many docs about the Macro and micro cells features on AP's 2800/3800, I understood the difference between both, but I am wondering how to implement them ?
Scott Fella
You must enable the FRA 5GHz on the supported AP to have a micro cell. The macro cell is on the default 5GHz radio and you only get a micro cell if the FRA is configured for 5GHz also on the same AP.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_cisco_aironet_series_2800_3800_access_point_deployment_guide/b_cisco_aironet_series_2800_3800_access_point_deployment_guide_chapter_01001.pdf
-Scott
6 Replies 6
Scott Fella
-Scott
Hello Scott,
Thank you for these informations !
If I understand well (please correct me if I'm wrong), if we turn FRA to have a second 5 GHz radio, we will have 2 cells for the AP, 1 macro and 1 micro, and what about the 2.4 GHz ? It will not be used anymore ? meaning we have to ensure clients don't support 2.4 GHz only ?
Correct, if FRA is used on the AP and it has changed both radios to 5GHz, it will only be able to serve 5GHz clients. As you've alluded there will be a marco and micro cell.
Fred Niehaus has presented about this several times, check this video out from when he reviewed the technology at Tech Field Day earlier this year.. https://vimeo.com/253962410
Evan Wheatley
Great, thank you for your answer !
No problem. Glad to help.
-Scott
