03-11-2009 07:58 AM - edited 07-03-2021 05:17 PM
I run a large wlan. however i have a branch site that requires just 1 cisco accesspoint ( i have a spare 1240g ap )
I would like to make this a standalone AP connected to the lan which can manage client authentication and association. It will be connected to cisco poe switch and the site is run by a cisco router.
the laptops will require static addresses.
whats the easiest way to play around with an test a 1240g ap in fat mode ?
also is there any other new ap`s perhaps a 5ghz or n radio device that can be run solo ?
cheers
Phill
03-11-2009 03:53 PM
Hi Phil,
Have you tried using H-REAP?
H-REAP Modes of Operation Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc3b8.shtml
H-Reap Design and Deployment Guide
http://www.cisco.com/en/US/products/ps6087/products_tech_note09186a0080736123.shtml
Hybrid Remote Edge Access Point (H-REAP) Basic Troubleshooting
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008081103d.shtml
Hope this helps.
03-12-2009 05:25 AM
Hi leolaohoo,
thanks for your replyi will read these documents.
cheers
Phill
