managed ap not broadcasting ssid
s sa
Ap 1832i is joining wireless controller 2504 normally. But not broadcasting ssid, another series is working properly and broadcasting except this series.
21 Replies 21
Hello s sa. how did you finaly solved this issue ?
i experience same one on 5508 with 1132i : no ssid broadcast
has anyone an idea ?
best Pierre
HI Pierre,
Please check if there is any AP groups(except default-group) on WLC. If yes then add the WLAN in the specific AP groups.
WLAN > Advanced > AP Groups
Also paste the output of : sh wlan <id>
Dont forget to rate helpful posts
OK,
as the aironet 18XX do no support TKIP anymore SSID with tkip isn't broadcasted...
solution : replace tkip with aes.
Best regards, Pierre
1. First check AP is connecte dproperly!!!
2. older then 8.3 version: TKIP was not supported. so you can try to change ssid to WPA2/AES and try again.
Hello friends how did your finaly solved this issue
i experience same one on AIR-CT2504-K9 with AP1832I-E-K9 i : no ssid broadcast
software version : 8.1.102.0
Did you check the regulatory domain of access points? i must to correspond to the country where are these located.
Hi, what is your country?
