Management Vlan best practices
SAM-Al
Community Member
Hi guys,
Would you please advise about Meraki best practice for the management vlan?
In my test network I have pair of MXs followed by pair of aggregation switches which feed couple of access switches and WAPs...
All my vlans are configured in the aggregation switches where the intervlan routing happens....the current management vlan for the WAPs and the switches is Vlan 1 which is same as the MX gateway that facing the aggregation switches.
Any idea about the best practice that I should follow?
I know above can cause issue for especially I'm planning to use RADIUS server one will sit in house and back up one in Azure.
Please let me know
thachung
Hi @SAM-Al
It is recommended to have a dedicated VLAN for management traffic, although not always required, per our KB article for Understanding and Configuring Management VLANs.
In your case, I would recommend configuring your aggregation switches' management interfaces in the transit VLAN (so that they can still function if anything happens downstream), and then creating a management VLAN on the aggregation switches for the remaining downstream equipment (access switches, APs, etc).
As long as routing is configuring properly, you shouldn't have an issue with on-premise or cloud based RADIUS server.
Cheers,
-Alex
If this was helpful, click the Kudos button below.
Please mark it as a solution if solved your issue so others can benefit from it 🙂
thachung
Hi @SAM-Al
Cheers,
-Alex
