management vlan on access point
tgusset
Hello
If I connect my access point (1130) to a switch trunk port (because I need different VLANs on different SSIDs) how can I define on which VLAN the APs IP address is?
Must it be the native VLAN? If so, where do I have to define it?
Thomas
sethgarnar
Level 3
Level 3
you will need to add the management ip on the native vlan via BVI1
interface BVI1
ip address 172.16.10.28 255.255.255.192
no ip route-cache
do a conf t
then in bvi1
ip add xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy
where x is the IP and y is the netmask
dcavanaugh
Level 3
Level 3
When you create the multiple subinterfaces under your fastethernet config, you need to enable dot1q on the subinterfaces. Then mark your management subinterface vlan as the native vlan. Do the same for the switch port.
