05-12-2009 11:37 AM - edited 07-03-2021 05:35 PM
I have a 1242 set up as a RAP and I have 3 remote 1242 MAPs I want the MAPs to always connect to the RAP directly is there a way that I can influence this?
Solved! Go to Solution.
05-13-2009 04:06 AM
Hi, since the AWPP is responsible for Path Election there is no way for Configuring a Child - Parent Pair. The Calculation is based on "easyness", which means RSSI and some Thresholds. Ensure a good Site Survey. Regards
05-13-2009 04:06 AM
