map
CSCO12204350
Community Member
                   Hi colleages,
i have a question regarding WLC Cisco , when I try to access to moniter i cant found the MAP option and the verion is 7.0.98.0
George Stefanick
Map ? The wlc doesn't have maps. Maybe you mean wcs ?
5 Replies 5
George Stefanick
ys this for WCS , and i canot found the map in the moniter ,how can be slove this issoue ?
In WCS you have to first import the MAPS in your WCS system. Have you done that yet or are you asking for help importing the maps ?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Hi George Stefanick
IN the WCS i cannot see the map ?
and how can import the MAP ?
It's pretty easy .. Read this
http://www.cisco.com/en/US/docs/wireless/wcs/7.0MR1/configuration/guide/maps.html
