Max. Devices in a AIR-LAP1142N-E-K9 Access Point
How many Wifi devices simultaneously support a AIR-LAP1142N-E-K9 Access Point?
Thank you
Surendra BG
I hope you are looking for the maximum clients that the LAP supports.. here is the lin kwhich gives you the exact info that you are looking for..
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70ccfg.html#wp1085099
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
Surendra BG
Surendra
Surendra BG
Hi Surendra BG,
Thanks for your reply. It was just what I was looking for.
Bye
I know this post is pretty old, but I just finished my CCNA Design and the recommended amount of users on the LWAP was recommended at 20 users.  I know this is a recommendation and not the max, but 200+ users does seem like a lot vs the recommended of 20 users per the exam.  Which of these are correct, or do the users experience decreased performance past the initial 20?
Thank you
