Max number of 1250s 20mW on 3750-E?
Jason Aarons
Level 6
Level 6
How many Cisco Aironet 1250 APs running 3x2 at 20mW under Cisco Enhanced PoE are supported on 3750E-48PD? Does it change with 3750E-48PD-F? How about X4648+E blade from 6500?
Where can I find a power calculator for 3750E?
I once had a customer buy 48 Cisco 7970 phones to find the 3560 switch couldn't power them all. Trying to avoid a repeat of that scenario.
Scott Fella
Here you go, but it doesn't have the 1250 as a platform.
http://tools.cisco.com/cpc/PFN.cpc
-Scott
it really depends on your power supply. The 750w will allow you to have 40 ports, but the 1150w power supply will give you all 48 ports.
-Scott
