wireless network needs keepalives (pings)
carl_townshend
Frequent Contributor
Hi all, We have a wireless network, consists of 1 access point that connects to 3 workgroup bridges, for some reason when I stop a ping going to all the access points, I can no longer reach devices the othr end of the workgroup bridges.
Is there a reason for this, config ? or bug?
As I have no fix for it at present.
Carl
6 Replies 6
carl_townshend
Update - After looking at the syslogs, It seems to drop every 10 mins.
What version of code are you using?
The older version of code had issues with ARP tables and caused this symptom to occur.
Hi There
The version is this
C1200 Software (C1200-K9W7-M), Version 12.3(8)JEA
Is this the version affected? what should Ido to cure the issue?
cheers
Carl
Nah Thats autonomous. Only LWAPP was effected.
Hi There
What is the latest software for my access points? is there any other fix for this ?
Recognize Your Peers
