Max. number of WLCs per WCS
I know this is a fairly basic question but I can't find answer in WCS Q&A's etc.
I'm looking at a deployment where there will be many small sites with only 5 or 6 APs and a 2106 WLC. Each site will be in a different mobility group.
I know WCS licensing counts APs, but is there a max. number of WLCs?
Thanks, MH
Rob Huffman
Hi Mark,
The supported number of WLC's per WCS is based on the WCS Platform used :)
Minimum server requirements
Cisco WCS High-End Server
• 3000 lightweight access points, 1250 standalone access points, 750 wireless LAN controllers
• Two Intel® Xeon Dual Core CPU's; 3.0 GHz, 8 GB RAM, 200 GB HDD
Cisco WCS Standard Server
• 2000 lightweight access points, 1000 standalone access points, 150 wireless LAN controllers
• Intel® Dual Core CPU; 3.2 GHz, 4 GB RAM, 80 GB HDD
Cisco WCS Low-End Server
• 500 lightweight access points, 200 standalone access points, 50 wireless LAN controllers
• Intel® CPU; 3.06 GHz, 2 GB RAM, 30 GB HDD
CiscoWorks WLSE Models 1130-19 or 1133 running Cisco WCS
• 1500 lightweight access points, 100 wireless LAN controllers
• Intel Pentium 4 CPU; 3 GHz, 3 GB RAM, 38 GB HDD
http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/product_data_sheet0900aecd802570d0.html
Hope this helps!
Rob
waynesymes
Chapter 2 of the WCS Configuration Guide:
3000 APs/750 WLCs on a High End Server.
