Max transmit power for different 5GHz bands
Srin_G
Level 3
Level 3
We statically assign power and channels in our wifi environment. For 9130AXI, what is the maximum power we can configure on UNII1,UNII2 and UNII3 bands. A simple table, with WLC power level (1,2,3 etc) relating to Db and Mw would be very helpful for each 5Ghz bands.
Appreciate any help.
regards
Radu96069
Check this link Cisco Catalyst 9100 Access Points - Install and Upgrade Guides - Cisco
You can download and excel file for your version of ios xe.
Then look into excel for your region. For each region there are 2 tabs for 5Ghz depending of maximum number of antennas you use per radio I think (4 or 8). If you use both 5Ghz Radio at the same time, the second one will have the lowest power available (level and you cannot modify it.
