maximum clients connected to cisco AP
vishalpatil86
hi,
I have 1242AG. how many clients can be connected to this AP??
Leo Laohoo
Depends on the situation.
Cisco recommends no more than 25 clients per WAP.  But this value is subject to "debate" in regards to the type of traffic involved.
If, for instance, the type of traffic is mostly (sporadic) emails, web browsing, etc ... then the value can go up to 35 clients per WAP.  However, if the type of traffic is video then the value is around 8 to 10 clients per WAP.
thanks for the reply....
i have two access points and 60 clients,
so who will decide to which AP to connect;  either AP or Client itself?
The client.
Scott Fella
Sent from my iPhone
-Scott
The client.
Otherwise, a nano-sized leprechaun inside the wireless NIC card will flip and golden coin in the air and the decision will be made.  Happens when you are inside or around an Irish bar.
