mohanak
In high density deployments we regularly see upto 100 clients on a radio. From a design perspective for enterprise typicall quote 30 clients per radio suggests to provide a good user experience. If I was seeing many more than this I would like to think about adding aps. What you may often see is access points deployed where we only have the 5GHz radio switched on to limit co-channel interference. Also keep in mind that the AC module for the 3600 only supports up to 50 clients and 7 Eplicit BeamForming clients. Just while you are looking at your numbers of clients in an area.
http://www.cisco.com/c/en/us/products/wireless/buyers-guide.html#~accesspoints
hajia
Usually I'll suggest 20-30 clients per AP, but if you use jitter sensitive apps like jabber or vowifi, I'll suggest you to allow less 20 clients per AP.
Becase they use the same channel, and CSMA/CA, so the more user you have, the more jitter you feel.
