Maximum number of AP supported has already joined cisco
Dear all,
We have vWLC, AP connected through MPLS network,  we also have ap base license for 15 AP, the problem is that AP cant joint to WLC because of
this error:
WLC shows that all 15 licenses are used, but we have only 3 AP
What is that? bug or not?, everything worked fine before we put new 4 AP into the network
thank you
I attached outputs in photos:
3 Accepted Solutions
HI Kamran,
You can ask about these issues to "licensing@cisco.com"
Dont forget to rate helpful posts
You license is fine or else it wouldn't of taken on the vWLC, its also active....  I would open a TAC case with the wireless team and see what they have to say.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Leo Laohoo
Kindly post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh ap summary
13 Replies 13
Sandeep Choudhary
It must be some kind of bug :U can also directly contact to TAC.
But we can try this:
Can you reboot the WLC ?
Console to AP and reboot it then put the entire process here.
Also paste the outpit of there:
WLC: sh sysinfo
AP: sh version
İ already rebooted it, but still stis problem, only when i back it to evalutaion license, ap join and works fine
but thet cant join when the main license is in use
HI Kamran,
Scott
-Scott
Leo Laohoo
1.  WLC:  sh sysinfo;
This license is evaluate and it works fine, but when it is our license it shows no AP in summary
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.60
RTOS Version..................................... 7.4.100.60
Bootloader Version............................... 7.4.100.60
Emergency Image Version.......................... 7.4.100.60
Build Type....................................... DATA + WPS
System Name...................................... Cisco VWLC
System Location.................................. ESXI
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 192.168.6.1
System Up Time................................... 0 days 17 hrs 29 mins 9 secs
System Timezone Location......................... (GMT +4:00) Muscat, Abu Dhabi
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries:BY,MX,US
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 7
Number of Active Clients......................... 41
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 00:50:56:9F:68:43
Maximum number of APs supported.................. 200
(Cisco Controller) >show ap summary
Number of APs.................................... 3
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model              Ethernet MAC       Location          Port  Country  Priority
Meeting_Room         2     AIR-LAP1142N-E-K9      54:75:d0:f5:3a:e4  default location  1        BY       1
Fttb                 2     AIR-CAP3602I-A-K9     30:f7:0d:29:03:42  default location  1        MX       1
Technical            2     AIR-LAP1142N-E-K9      c8:9c:1d:f4:72:8a  default location  1        BY       1
You should open a TAC case with the wireless team. Since your AP's join fine with the evaluation license and not the PAID license, there must be something wrong with your vWLC. The wireless TAC team can work alongside the licensing team if it indeed is a licensing issue or if maybe they want to regenerate another license for you.
-Scott
I'm going off a regular WLC and they have a base license along with a base-ap-count. When you revived your pak files and generated your license, did you only have one license and not the base license also. If you did receive a base license with 0 ap, that has to be installed first, then your base-ap-license of 15. You would have to remove the 15 license firsts and install the base then your 15.
-Scott
Thanks for the output.
The reason why your AP won't join is because you have enabled multiple regulatory domains and they CONFLICT with each other.
You have enabled countries of Belarus (-I), Mexico, and the US.
Sent from Cisco Technical Support Wii App
Thanks for your response,
ill check it and i will tell you
I changed it to GB, but again wlc says that
maximum AP is already join (we have only 3 ap)
hI Kamran,
This is the problem with Licence, please send a mail to: licensing@cisco.com
Or call TAC customer care: http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
Tell then about ur licence issue, may be they can help u:)
tzoucha
I ran into this same issue after a reboot of the vWLC.  I saw in the web GUI  that I didn't accept the EULA thus the license was not active.
WLC Web GUI > Management > Software Activation > Licenses > base-ap-count
status:  EULA not accepted
I togged the priority to high and the EULA popped up and I accepted it.  The APs connected to the WLC.
Hope this helps
