maximum rssi
jerry.larson
I have clients connecting at -90 -95 RSSI range. How can I configure to insure nobody below -78 -80 connect to an SSID?
thank you,
Benoit Loriaux
Level 2
Level 2
Hi Jerry,
There is a very radical way of doing things but you have to be extremely careful with this, usually it's applied in very high density environment.
But let's do it smooth
Have you disabled the low data rates ?
Please be aware that disabling 11Mbps will kick away all the legacy 802.11b devices.
Alexey Belousov
Level 4
Level 4
you can check the box "RSSI Low check" and configure RSSI Threshold (WIRELESS->802.11a/n/ac->network)
RSSI LowCheck
Check box that you can enable to reject a client association request if the Received Signal Strength Indicator (RSSI) is lower than the configured RSSI threshold.
RSSIThreshold
RSSI Threshold that is used to reject the client association request. The range is from –60 to –90 dBm. The default value is –80 dBm.
